- Grit_dogNavigator
Ozlander wrote:
cmcdar wrote:
Grit dog wrote:
This is one of the least informed responses I've seen on here in....well actually about a day.
Rvnet, the land of fiction and fallacy.
Grit dog, Please provide some kind of evidence to support your assertion.
Thank you.
Which part of this do you think may not be true.
Ok,ok.
OG said it was cool in a MH but not a trailer. Why the distinction?
Valve on or off on a propane tank, it has no greater propensity to explode. If gas gets out too fast, like a broken gas line, check valve shuts off the supply.
If a tank gets too hot, it will release gas like a flame thrower (so as to not explode) whether valve is on or off.
If a fire starts from an open flame (pilot light or furnace / fridge burner) how is that related to being in motion vs parked?
Those were my points.
And to address the “turn off propane in tunnels or on ferries” rules, that is so there is not an open flame in a potential confined space that could fill with flammable fumes. You could have tank valve open but no pilot lights But It’s a catch all. - westendExplorerI thought warming up the trailer was all part of the setting up experience? :B
It should be safe to run the furnace while travelling. There may be air issues because of vent configurations but the furnace will shut off in that case.
For me, a 1200W electric furnace will warm the inside air from 30f to 80f in less than 1/2 hour. My propane heater with auxiliary disbursement fans is faster. It does take a few hours to warm all the mass inside to comfortable temps so I could understand a pre-heat or operating the furnace while underway.
One project I'm looking at is using hydronic heat. I could be using excess solar power, use a solar heater, run it off the RV's water heater, or a combination. I have a steel water tank under a dinette seat and it takes a lot of heat to bring it up to room temp. - Luke_PorterExplorerIf the slides block the flow of air, the furnace will shut down.
- OzlanderExplorer
Thank you.
Which part of this do you think may not be true. - memtbExplorerjack buck, we do a bit of winter travel (sometimes below zero F) with our fiver, water tank full and water system full,so... keeping heat on is a must. But most of our trips are short so battery consumption is not an issue. On a very long trip (as stated) a generator to maintain batteries may be needed. Or.... and I “ have not” researched this (though I did this on an old ‘84 Ford to charge our 5th wheel batteries), rewire to your truck 7 pin connector with a separate lead from truck battery ( the original lead is “only” to maintain your unit batteries and is of low amperage). But..... you must unplug when truck “not” running, so as “not” to pull down your truck batteries!
- cmcdarExplorer
Grit dog wrote:
old guy wrote:
in what? inn a motor home yes, in a TT ot such a great idea. I'm a safety nut, I don't travel with my propane on, nothing like a snow on the road type accident to blow the hell out of things. I fought fires for 30 years and many were RV fires on the roads of eastern Oregon and believe me with a rv full of propane it gets nerve racking. I have posted on here many times of fires caused by rv frig's and nobody thinks about it. they foolishly think well, it's never happened to me. I say never happened yet.
Do you turn off the gas and power to your house at night before you go to sleep too?
Oh wait, it's ok in a Moho but not in a trailer....
Thank you. - rhagfoExplorer IIIIn Winter we would run the furnace while on the road at about 55 degrees, 5er would be nice and warm to start with.
- Dave_H_MExplorer IIDang Grit Dog, i was just gonna let that sleeping dog lay. :B
- Grit_dogNavigator
Oh wait, it's ok in a Moho but not in a trailer.... - FunnyCamperExplorer IIyou can but we don't. Like IdaD said, I feel they heat up very fast when we arrive and turn it on.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
