โAug-05-2016 11:23 AM
โAug-06-2016 12:15 PM
Acdii wrote:
Well this is one I hadn't considered, but now that I think about it, Between where you connect the hose, and the check valve, how do you get antifreeze in there, or blow out the water that is sure to be there?
Would it be better to get an air line adapter, plug it in there, and blow the system out from there?
โAug-06-2016 07:56 AM
โAug-06-2016 07:50 AM
โAug-06-2016 04:49 AM
DrewE wrote:
The check valve is typically built into the city water connection itself, a part of the hose connector assembly. There's no appreciable amount of water that gets trapped there. If you're still concerned, you could always pump antifreeze through the city water inlet.
Blowing out the lines with air is, of course, a perfectly valid approach to winterizing in general.
To the OP: If the hot water heater has been bypassed all year, then there's no need to do anything to it to winterize it--it can stay bypassed. It would be a good idea to remove the drain plug (if it was installed) to make sure there's no water in the tank when it comes time to winterize. The interior pipework does need winterization as always, though; not using the fresh water tank just means that it's not necessary to drain it for winterization, but no further reduction in the work involved.
โAug-05-2016 02:43 PM
โAug-05-2016 02:40 PM
โAug-05-2016 02:10 PM
โAug-05-2016 01:27 PM
โAug-05-2016 11:40 AM
โAug-05-2016 11:29 AM
