โFeb-08-2019 06:32 AM
โFeb-10-2019 06:03 PM
Sorry...my memory was bad. 2756 is the load rating of each tire. I guess the tires WOULD be fine for your 4800# rear axle rating. The tire is the Primacy XC so maybe not really a P rated tire.
โFeb-10-2019 09:05 AM
Atlee wrote:Sorry...my memory was bad. 2756 is the load rating of each tire. I guess the tires WOULD be fine for your 4800# rear axle rating. The tire is the Primacy XC so maybe not really a P rated tire.
Obviously, it depends on the 1/2 ton truck doesn't it? Two 2300# tires on my rear axle do not equal the rear axle rating of 4800# my F150 has. Ford put OEM LRE tires on it, but my 2014 truck has the HD payload package.
Now, I understand Ford began using LTC tires on later models with the HDPP so maybe they decided LTE tires were overkill. However, since LTE's were on my truck originally, I'll keep putting then on.
babock wrote:
I have the exact truck and will stick with the P tires vs going LT. At least with my trailer, 6000# and 800# of TW, the trailer tows fine with these tires. Each of my truck's Michelin P tires is rated over 2300# my 4 which means my 4 tires are already rated way higher than my max GVW! I prefer to keep the softer ride when not towing as long as my tow experience is already fine.
โFeb-09-2019 06:38 AM
โFeb-09-2019 04:38 AM
โFeb-09-2019 03:34 AM
โFeb-08-2019 10:31 PM
โFeb-08-2019 10:08 PM
โFeb-08-2019 09:52 PM
Ralph Cramden wrote:
LOL :S :h
The OP has a 2018 F150.
3 different wheel sizes available on an 18 F150. Depending on package if it came OEM with P275-65-18 44 max psi or LT275-65-18 80 max psi they're still mounted on the same wheels. Ford is not using one wheel for this tire, and another for that tire, nor is GM, Ram, or anyone else unless you get into something special, like the Raptor.
The OP has not cobbled his 2018 truck together from some pile of 1970's parts he found out behind the barn, or has he?
โFeb-08-2019 08:38 PM
โFeb-08-2019 08:06 PM
MitchF150 wrote:
I only thought your "real truck" comment was the silly part...
I guess if only HD or heavy trucks are "real trucks" then... Well..
I'll just leave it at that...
Mitch
โFeb-08-2019 07:57 PM
โFeb-08-2019 07:42 PM
MitchF150 wrote:
Wow Scott.. Never thought you would go there... You been reading too many of oldmans posts I guess.. ๐ he likes that "real truck" thing too... I've always respected your posts in the past..
With my 20" wheels the sidewall on my tires are only 4.5"..
I don't recall the actual sidewall height on my old F150 that had 265/75/16 Lt C tires on them, but they were at least an inch or so more sidewall.. They did fine too. Yes, the P rated tires sucked.. I will give you that..
But until you have actually used the tires in question with the vehicle in question, your "real truck" reply is just silly.
Oh, I have used LT E tires on an F150 and they were a complete WASTE of tire and cost me payload and ride comfort and mpgs.. They didn't make a bit of difference towing compared to the LT C tires I had on the truck (that same 97 F150 I had before).
Mitch
โFeb-08-2019 07:19 PM
ScottG wrote:MitchF150 wrote:
Since the rear axle rating is only #4050 I'd say the tires far exceed the axle rating so why get LT E tires???
Mitch
For the handling associated with the stiff sidewalls. If you haven't tried LR E tires then you don't know what a difference they make.
That's the reason real trucks use truck tires.
โFeb-08-2019 06:57 PM
