BarneyS wrote:
I painted all the yellowed plastic parts on our trailer about 13 years ago and they still look like new today. Used Krylon plastic paint as already mentioned by posters above.
I did mine about 8 years ago and it still looks new.
The big trim piece around the skylights started to turn yellow too, so I removed them and painted them as well.- BeakerExplorerPlain old bleach will turn it white but will yellow again.
I painted mine. - blofgrenExplorer
ScottG wrote:
I painted the white frames on our last TT with Krylon Fusion. The results were beyond what I could have hoped for. Not only did they look like new, they also stayed that way for 5+ years until I traded it in. There were some small cracks in them that the Fusion filled as well.
Scott
This is exactly what I did and it worked fantastic. - keymastrExplorerYou do know they make clear replacements with internal privacy blinds, right?
https://www.amazon.com/AP-Products-015-201512-Upgrading-Window/dp/B01MRRNQNP/ref=sr_1_4?crid=23NL92Y7LCDHO&keywords=rv+door+window+with+built-in+shade&qid=1577754281&sprefix=rv+door+window%2Caps%2C353&sr=8-4 - NJRVerExplorer
larry barnhart wrote:
Cummins12V98 wrote:
Window directly to left I can see out just fine. Window to right is bathroom.
Most door windows have frosted glass so why have it???
Ours is clear. Frosty would not be of any valve.
chevman
Frosted lets light in, but keeps nosey eyes out. - larry_barnhartExplorer
chevman - Chum_leeExplorer
Lynnmor wrote:
You can try wiping the yellow plastic with acetone on a paper towel. Wipe once and toss the paper towel, do not keep rubbing.
I agree with this for a quick clean only. When the technician replaced my Dometic 2652 refrigerator, in order to remove some of the adhesive tape residue from the new black plastic cabinet trim bezel, (the trim filler piece) he used an acetone soaked rag and wiped, . . . . . several times too many. That was the end of the factory textured finish. Now it's smooth as glass in a few locations, textured in others. Ooops!
Chum lee - Cummins12V98Explorer IIIWindow directly to left I can see out just fine. Window to right is bathroom.
Most door windows have frosted glass so why have it??? - larry_barnhartExplorerwe like our door window and all of our windows on both sides and rear and slides because we like to look at the action.
chevman - Cummins12V98Explorer IIISimply order it without the USELESS window in the first place!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Feb 25, 2026
