InTheRockies's avatar
InTheRockies
Yellowstone Next Week - Freezing Temps Concern
I’ll be in Yellowstone next week in my TT and am concerned about temps dipping below freezing at night. My holding tanks are all exposed below the underbelly. I can easily run some RV antifreeze through my supply lines via the water pump and use water containers for my fresh water needs, but am not sure about the waste tanks. I won’t be able to avoid using the gray and black tanks. I can pour antifreeze in the drain lines but it will be diluted by the gray and black waste water. Is the answer just more antifreeze? Any temporary and easy insulation I can rig up for the exposed tanks and low point drains?
Forecasted low temps look to be around 30-35. Am I worrying too much?
Thanks in advance.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 15, 2025
