bid_time
Jun 26, 2024Nomad II
If you are truly plugged into 220 volts than you have made a big mistake and may have caused major damage. Your unit is not 220 volt capable. You should be plugged into two legs at 120 volt each at 50 amps each leg (or possibly one 120 volt leg at 30 amps). To start to clear this up, post a picture of the plug on your rig and the receptacle you’re plugged into.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
