โDec-04-2016 04:17 PM
โDec-06-2016 06:00 PM
westend wrote:
Since this is a subpanel you're working with, it also involves the main load center and associated breakers in that box. The sub panel breakers and associated circuits may be connected to the same bus or circuit in that main load center.
One breaker may also be back fed by the other if there is a junction box or device box where they are connected together.
โDec-06-2016 02:15 PM
โDec-06-2016 01:31 PM
trailrider wrote:enblethen wrote:
Look for the larger #10 wire coming from the shore power cord. Many go to the screw terminal on a 30 amp breaker. This feeds the rest of the breaker via the buss work.
The screw terminals on the 15 amp breakers feed the device/receptacle.
I am guessing that some one replaced the 30 amp breaker with a fifteen amp.
This post got me to thinking. On this rig the subpanel has the 30 amp inverter input breaker on the far left, then the 15 amp refrigerator breaker, a couple more 15 amp breakers for various things, the microwave 15 amp breaker and one more 15 amp breaker far right.
See if this scenario makes sense. This is me guessing what might be the problem, [COLOR=]the rig is not available for me to look at anymore
The input wire from the inverter and the refrigerator wire are hooked backwards. So the input from the inverter is actually hooked to the 15 amp refrigerator breaker and supplies the rest of the breakers on the panel. I never thought to check the other circuits to see if they are all dead if the refrigerator breaker is off. He only mentioned the microwave being dead after the refrigerator breaker tripped.
โDec-05-2016 02:50 PM
โDec-05-2016 01:02 PM
โDec-05-2016 09:39 AM
โDec-05-2016 09:33 AM
trailrider wrote:
It is a 30 amp sub panel fed from the inverter. I already took the cover off and verified that each breaker is wired to it's own separate romex. Once those romex leave the box I have no idea what happens down the line.
โDec-05-2016 08:47 AM
Bud
USAF Retired
Pace Arrow
โDec-05-2016 08:41 AM
โDec-05-2016 05:34 AM
โDec-04-2016 07:02 PM
โDec-04-2016 06:51 PM
time2roll wrote:
So it is a two pole breaker and each has separate romex.....
Any chance the microwave and fridge are plugged into top and bottom of the same duplex outlet?
I would remove both romex (hot) and verify power and breaker function with a multimeter or voltage detector. Post the results but I think it will check OK. Then attach one romex to one breaker and see if it back feeds on the other romex. Then swap and check the other direction. Post the results.
Need to divide and concur. Test each section separated from others. Otherwise it is just a swirling mystery.
โDec-04-2016 06:17 PM
โDec-04-2016 06:02 PM
Bud
USAF Retired
Pace Arrow
