Scott_99's avatar
Scott_99
120 Volt Plug-ins Not working
The plug-ins on my Sunset Trail stopped working, the breakers are both good and not tripped. I checked the power supply and it ok. I was wondering if there was a safety rely past the main breakers? Or could it be something else.
  • Scott_99 wrote:
    Thanks for the help, it was the ground fault plug in the bathroom.
    Simple cheap fixes are the best type of repair.
    Glad you got it back in service quickly.
    Thanks for posting the solution. Glad it was something simple.
  • Thanks for the help, it was the ground fault plug in the bathroom.
  • Sometimes, an exterior GFCI is in the circuit and they can be difficult to find. If you have an outside kitchen or big storage bins, take a look.
  • X2 on the GFCI tripping. Mine is located in the bathroom and protects all of the outlets in the RV.
  • The power to the trailer is good, everything else works fine. I reset the breakers and still nothing. There are two breakers for the plugs one for front and one for the back, and there is power coming off both breakers.
  • did it stop working while you were plugged in at a campground or did it not work when you plugged in the next time? Have you checked the GFI's?
  • Did you reset the breakers, not just look to see if they were tripped?
    Sometimes they need reset.
    If you don't have a voltmeter, get one. If your power supply is good, check the power going into the main breaker in the RV.
    Do you have a GFI that controls all the outlets? Make sure that didn't kick off.
    Does you power supply cord plug into the RV or is it hard wired?
    If a plug in, unplug and plug back in, make sure there is no corrosion on the plug blades.
    Let us know when you find the problem.
    Hopefully, it's something simple.
