Rbertalotto
Apr 11, 2015Explorer
120V Converter Grounding Question ??????
I recently replaced my 20 year old Centurion Converter with a Progressive Dynamics 4700 series unit.
......In a truck camper, should the 120vAC ground buss bar from the converter be connected to the campers ground? In my camper there is a large copper wire connectected to the copper gas lines and to one of the tie downs that effectively grounds the camper to the truck. The ground from the 12V battery is grounded here. Should the 120V side be grounded here also?
The Centurion converter was not grounded in this manner. The PD unit does not have a separate "chassis ground" terminal.
Thanks
Thanks
