โMar-26-2020 10:54 AM
โMar-26-2020 02:00 PM
โMar-26-2020 01:58 PM
โMar-26-2020 01:53 PM
Flute Man wrote:
I have a 12 V 300 W heater in my rally compartment. It draws 25 A so figure yours accordingly.
Electric heaters have a very simple formula.
Watts Divided by volts equals amps.
โMar-26-2020 01:34 PM
โMar-26-2020 12:55 PM
โMar-26-2020 12:40 PM
DrewE wrote:
A big resistor that can dissipate a lot of power at 12V, sufficient to be a useful heater, is also a low-valued resistor, on the order of one ohm (approximately 150 watts). Making your own with resistance wire would probably be easier and less expensive than finding and affording a commercially produced resistor, marketed as such. Having a few coils wired in parallel is probably a good idea, too.
I'd think, for heating with solar power, that a solar water heater (as in a black pipe in a reflective trough or something similar) and a radiator of some sort would be more efficient and effective overall. The cost would probably be lower, too.
โMar-26-2020 12:29 PM
โMar-26-2020 12:05 PM
DarkSkySeeker wrote:agesilaus wrote:
Even small 120 VAC heaters are 1200 to 1500 watts...
Thanks. Yeah, I was imagining a big resistor with a heat sink around it that would run passively. Perhaps I will find that.
โMar-26-2020 11:26 AM
โMar-26-2020 11:13 AM
โMar-26-2020 11:03 AM
