- newman_fulltimeExplorer IIVery doubtful with today's emission standards if you put everything new on that motor it will pass.But if you want to put money into it a new carb and catalytic converter and new exhaust system will help
- 2oldmanExplorer IIWow.. a vehicle that old still has to pass emissions? I wonder how all those old stinky-ass pickups I get behind are allowed on the road. And those jackasses who blow black smoke, on purpose.
- LwiddisExplorer IIPer California DMV at https://www.dmv.ca.gov/portal/dmv/detail/vr/smogfaq
"Currently, smog inspections are required for all vehicles EXCEPT diesel powered vehicles 1997 year model and older or with a Gross Vehicle Weight (GVWR) of more than 14,000 lbs, electric, natural gas powered vehicles over 14,000 lbs, motorcycles, trailers, or gasoline powered vehicles 1975 and older." - shastagaryExplorerwhen we had emissions testing here on my camper van i had to adjust my idle mixture screws on the carburetor in until the engine just started to stumble at idle a bit to get it to pass. there was a one year exemption issued if it would not pass after several tries to give you time to get it fixed.
- Common problem with 360 is the exhaust cross over passage in the intake manifold. Ackward job to clean without taking manifold off.
Odd that the vehicle needs emission testing! - D_E_BishopExplorer1984 was the first year for mandatory use of converters, prior to that it was optional but if the vehicle came with one it is required. Test on vehicles are a little schety to beging with.
A cat actually makes C02.
Check and see if you can get a vintage vehicle exemption at that age you just might. - MEXICOWANDERERExplorerNo exemptions for commercial vehicles.
DATA allows perspective. List HC, CO, and NOX data. it will have max/min + your numbers listed. One such example a VACUUM LEAK will raise CO numbers. Can we see some numbers, please? - CO is the air/fuel mixture. Need a good carburetor adjustment or better just get a new one.
- markchengrExplorer IIThe OP said CO2 not CO. Emission tests require CO2 OVER a certain level, not less.
- landyacht318ExplorerJust passed California smog test with a 318.
@25mph and 1415rpm
%co2 13.3
%O2 2.5
Hc 83ppm---max allowable 102
CO% 0.09-----------------0.64
NO 118------------------870
