wolfe10
Oct 16, 2023Explorer
Rhalium wrote:
can the water heater work just fine on propane, yet still not work on 120 volt electric solely cause of the "element" located inside the hot water heater tank? in other words, the hot water will work fine on propane, but not work on electric cause of a bad element?
Certainly.
If the propane-side is working fine (12 VDC, good propane supply, thermocouple good, etc) all is good on propane.
If 120 VAC is not powering the heating element, it will not work. Could be issue with shore power, breaker, fuse in water heater PC board or burned out 120 VAC heating element-- will not work.
Basically two "mostly" unrelated heating sources. PC board being the point in common.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
