billcard
Sep 09, 2014Explorer
2014 Dutchmen Travel Trailer Brake Adjustment
Hi.
I performed a search of the forum but couldn't find anything that spoke directly to this question so I hope you don't mind my posting it.
My intent is to do full-time RVing when I retire in about five years so I bought my truck and travel trailer last month so I had time to pay them off.
So this is my first experience with a travel trailer in a long, long time. I'm admittedly a neophyte.
The trailer is a 2014 Dutchmen 202RBS that was supposedly brand new. However, I found lots of rust on the frame, suspension, and wheels and very sloppy silicon treatments on the "roof." I could deal with those (assumed it must have been that the trailer just sat in their lot for ages) but here's the real problem: Combo brakes.
My truck has the standard Ford tow/haul kit. I can set the gain easily using the dash control (pinching the two parts together and using the + and - buttons to make adjustments.
Additionally, the truck has a two assist "pressure" setting for which I can select low, medium, and high.
The owners manual says to set the gain to 5 as the default starting position and the pressure to low to begin testing the brakes, which I did. Took the rig up to about 25-30mph and applied the control pincers: No indication of any trailer braking.
Investigation showed that one of the pair of female pins in the trailer electrical coupling were bent to the side so I straightened them and insured that the coupling had no other issues, cleaned the contacts, then re-coupled the truck and trailer and tried again.
Now I could feel some drag on the rig when I applied the truck's pincers but still not what I'd expect. I adjusted the gain up to 8 and the rig still demonstrated minimal braking when I pinched the control.
I'm assuming the pressure setting on "low" means that I'll need to use minimal pressure on the truck brakes to activate the trailer brakes so I've left that setting on low.
Called Dutchmen to see if light brakes are normal: Definitely not, they said; take it to a Dutchmen-authorized dealer for diagnosis.
Looked online for instructions on adjusting the brakes myself and there are a lot of them that tell how to adjust them via the star gear/wheel.
Raised one wheel as instructed and popped off the two bottom dust covers and searched for the star wheel. No wheel. Spring, yes. Silver guide for the spring, yes. No star wheel. Didn't check another wheel because I'd been told, when I called around for a service appointment to adjust the brakes, that modern trailers don't have the star gear anymore. They're electronic and use magnets.
Well, all of the instruction that I saw for electric trailer brakes indicated that there were magnets, yes, but still indicated that there was a star-wheel and the means to adjust the actual brake shoes. That also seems logical to me since even electric brakes shouldn't completely bypass the mechanical braking system (but I could be way off on that).
So all of this is to ask you about your experience with electric trailer brakes:
1. Should I be finding a star-gear in my trailer's brakes? (Dual axle)
2. Would it be an actual star shape like brakes have had for so many decades or am I just not seeing it because its appearance is foreign to me?
3. Should I be able to adjust the brake shoes myself and save myself the money and time that I'd have spent on having the dealer do my adjustments? Or should I leave that to the dealer?
4. If yes to the previous questions, if I cannot find a star-gear in the wheel, what do you suggest? Pulling the wheel and opening the drum? I hate to do that for fear of contamination and I am a novice so have some trepidation but, if that's all that can be done, then I'll give it a try.
Any guidance you might offer will be extremely appreciated!
Thanks!
bc
Thanks!
bc
