Cherguin's avatar
Cherguin
Mar 25, 2024
2018 Mirada slide
I have a 2018 Coachman Mirada 35KB. It has 2 slides on the drivers side, the bedroom and the living/dining area.  The larger slide opens and closes fine but the sides of the slide are out of sync.  What I mean by that is the left side of the slide seems like it hangs up for a second or so before it starts to travel.  Once it gets going it’s fine. When the slide is all the way out the right side stops and the left side continues for about 2” until it catches up with the right side.  Has anyone experienced this?
  • That problem is not unusual. However, without us knowing what type of slide out system you have, no one will be able to suggest how to fix it. There a several, hydraulic, cable, rack and pinion, schwintek, etc. I would suggest looking through the literature for the vehicle, talk to the dealer or find some one knowledgeable of your rig to find out what kind it is so some one can help determine the fix.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
