Griffin_sride's avatar
Oct 25, 2016
220v in 110v system
My in-law accidently plugged my 30amp coach into a 220 dryer outlet. Now I'm trying to figure out if the ac side of the fridge is ruined. I already pulled the exterior cover and found one burnt fuse that I replaced. The control panel on the inside functions properly changing over to ac when shore power is connected but it will only cool if I switch it over to gas. Does anyone know of any other fuses I can check? I already pulled all the fuses on the inside and they're good. Does anyone know of a capacitor or other eletrical componet that may have burnt up that I can replace?
So far other that the tv and dvd player everything has been protected by fuses and are working again after replacing the fuse.
Fingers crossed on the fridge!!!
