DiskDoctr
Jun 07, 2017Explorer
time2roll wrote:
I would skip the NC Relay and pull power for the converter from the Shore input of the TS30.
Just add a fuse same as the prewired GP TS-30
Ahhhh! Now I get it...
Move the Converter/charger's power supply to the same terminal blocks in the transfer switch as the shoreline input cable. So it would only be powered if the shoreline cable/generator supplies power.
The inverter would still be "on" by getting 12vdc from the batteries, but its 120v output would be switched OFF by the presence of the shore/generator power.
I think that is okay. I can either turn off the inverter with its switch, or leave it running, since it won't have any load and the camper will have 120v supply from shore/generator providing charge to the batteries through the converter/charger- so no draining of batteries.
Sound about right?
Thanks!
