cecilpwv
Aug 01, 2005Explorer
I would like to rewire my PowerPro 3500 per MrWizard's instructions, but I am not clear on the instructions (page 48 of this thread). After splitting the white and red common wires and connecting them to brown abd blue, respectively, what else needs to be done? Referring to the schematic (http://www.y4hdesigns.com/images/PP3500schem.jpg), surely I need to disconnect the red wire from the neutral side of the 120 plug. Do I then connect the white/blue combo there? That strikes me as very wrong. Or does nothing now connect to the common side? If so, where does the white/blue wire go?
MrWizard also said to disconnect the 240 outlet and replace it with a 120 outlet, Could I not just disconnect it entirely? I would be satisfied with only one outlet (the tech rep said it is 30amp), and I would expect the job would be easier to accomplish.
Any advice is greatly appreciated. I don't know much about electricity, but I know enough not to attempt a job like this without detailed instructions to follow.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 18, 2026
