CA_Traveler
Mar 20, 2023Explorer III
For reference it's been discussed many times that a 50A 4 wire RV circuit is actually 2 120V 50A circuits allowing for 3 or 4 A/C units or combinations of other higher draw devices.
Without getting into the details of the 50A RV circuit which has been discussed many times this circuit can and does cause very high and low voltage when the common neutral is open or partially open which can be a pedestal or RV problem. Hence it's been my recommendation that all 50A RVs use a EMS protects against this possibility since high voltage can damage connected equipment in the RV.
In 2004 with my first 50A RV I installed the Progressive Industries HW 50C EMS which protects against an open 50A neutral and 10 other faults.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 07, 2025
