bounder39zman
May 11, 2019Explorer II
OK..fault code 47 is an ignition fault code. the control board is not "seeing" one or the other ignition coils. could be as simple as a unplugged wire, or a bad coil. I have had shop towels or paper towels get sucked up into the air intake, and dislodge wire off coil. So looks like you probably have bad coil, disconnected wire to coil, or possibly bad control board.. And , from experience, dont lay shop towels or paper towels near air intake....
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
