Seneca_35GS's avatar
Seneca_35GS
5" White Plastic Sewer Flange & Threaded Cap
I need the white PVC plastic sewer hose flange that is mounted on the floor of the sewer hose compt. in a '03 Monanco class A. A 5" threaded white plastic cap threads into this flange, while traveling to keep debris out of the utility compartment. This was a item on '03 Monanco's and other year Monanco's. The cap has the word TRUSTY embossed on the treaded cap,it's made in Tawain.
Would a RV salvage yard be the best place to buy this part, if so any suggestions.
Moved to Tech Issues forum from DIY.
  • Home depot has them in black ABS pipe for a lot less than a specialty store. I store my sewer hose behind one.
    EDIT: never mind, HD only goes up to 4" ($2.69) but a plumbing supply house should have 5" threaded cleanout plug.
  • West Marine has them but they must be ordered. They have the 4" and 6" in stock in the stores.
    You can also find it on E-Bay if you search for 5" deck hatch. I have the same thing in my coach (in black) so....been there, done that!
    5" plate on E-Bay
    By the way, the 5" is the size of the hole and not the outside diameter of the plate so be sure you buy the right size.
  • Even Camping World has them. Unfortunately I don't think you can buy just the top....Dennis
  • The marine post was right on, check out West Marine or a similar vendor.
  • I sent you a PM with my contact info. I have these in stock.
  • Won't a standard, off the self PVC pipe and accessories do the same job?
    Available at any plumbing supply or Home Depot type store?
  • Try a marine shop, they are used on some boats for sealed storage areas
  • Rv Salvage ----just goggle 'RV Salvage in (your area)'
    Or call Monaco
    Technical Support, Parts and Warranty Assistance: (877) 466-6226
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 24, 2025
