BurbMan's avatar
BurbMan
Apr 25, 2022
50A RV with 30A plug?
Our new-to-us 5er is wired for 2 a/c's but only has one installed. The factory installed a ceiling vent in the bedroom, and when you remove the inside trim around the fan you can see the #12 120v wire in the ceiling and there is a 20a breaker in the panel labeled "bedroom a/c". So it looks pretty easy to take out the roof vent and replace with a 2nd a/c unit in the bedroom.
The panel has a 50a main breaker, but the shore cord has a 30a plug on it...is there such a thing as an "adapter cord" that doesn't require a dogbone? Am I correct that all I need to do is replace the shore cord to get 50a to the rig?
Here's the RV end of the shore power cord:
Now here's the plug end of the shore cord:
This is connection on the outside of the rig:
The inside breaker panel:
On a related note, I'm not sure I want to add a 2nd a/c in the bedroom...we dry camp a fair amount and at least I'll get some air movement with the vent, the a/c blocks that vent spot and the only way to get cold air is to plug in. Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
