brutherb
Apr 15, 2018Explorer
87 triple e regency converter issue
New to me motorhome has an allson d40-bra-e, converter seems to be working fine, but when i connect the line to the batteries the voltage jumps up to15/16 volts, disconnect the wire and it drops down to high 12/13 ish.
also there is a spring loaded points device that on one side reads 13.?? volts nothing on the other, then when you depress it it send the voltage through to the other side, its part of the floating charging system, but what make the point device engage as its not, i manual do it.
i know there are newer better units out there but i would like to get this one working if possible for this season
