swiederin's avatar
swiederin
98 Hitchiker II Water Heater Wiring
Bought our Hitchiker II 5th wheel and need to replace the water heater. It is a combination gas/electric unit. No problem with that except, I don't understand the electrical. Specifically this...there is a remote rocker switch and indicator light that has DC running thru it. Is that for the gas igniter? How does it work.....when does the light come on?
Also, there is a wall switch above the counter that has a pilot light next to it. What does that do? Is it the on/off switch for the electric portion? Any explanation helps. Thanks.
  • swiederin wrote:
    The model is #GC6AA-9E. I am replacing it because it had a leak in the tank.
    OK....
    That is a GAs/Electric 6 gal but the last of the versions where Gas & Electric used separate controls
    120VAC should come from a 15A Circuit Breaker in your Main AC Panel
    From CB 120VAC would go to the Electric On/Off Switch on cover box under which is 120VAC Set of T-stats & element (backside of WH Tank
    12VDC should be from a FUSED DC source (DC Dist Panel) to 'thermal fuse' (clear tubing above burner) then to T-stat and to circuit board (Brown wire)
    From circuit board to ECO & gas valve (Red wires)
    Gas On/Off Switch will have the FAULT Light
    IF-----IF previous owner installed an INSIDE switch for 120VAC Element then it would be wired in series with OEM switch (both have to be ON for element to get 120VAC OR OEM Switch was deleted from circuit and Inside Switch turns Element on/off
    You would need to check how it is wired at backside of WH TANK and that 'wall switch with pilot light' is probably a 120VAC switch with Indicator Light to know when WH Element is on/off
    (Check voltage to that switch.....120VAC??
    You can get a new tank....swap you current components over
    Atwood 91593 roughly $199
    9E Replacement TANK
    Or new GC6AA-9E water heater
    Atwood AT96121 roughly $472
    New 9E Water Heater----complete
    OR have old tank welded up....lots of folks have done this
    12VDC Wiring (7e thru 9e use same schematic)
  • The model is #GC6AA-9E. I am replacing it because it had a leak in the tank.
  • 1998 HitchHiker with gas/electric combo
    That should have totally separate controls for gas and electric
    120V Directly to the On/Off Switch on backside of water heater...protective cover under which is the 120VAC set of t-stats and element
    Gas would have an inside on/off switch with Red FAULT Light which would be triggered by failure of Flame Ignition
    Atwood Water Heaters did NOT start using DC Controls for gas AND Electric until 2004---Present
    In outside compartment should be a Data Sticker that lists MODEL of that Water Heater
    If you have DC on/off switch that controls electric then that water heater has been changed out and the DC Switch added as part of the conversion
    2004....Present Combo Units
    6 gal would have a 10E at end of model number
    10 gal would have a 4E at end of model number
    DC on electric goes to a DC Relay that triggers 120VAC to element
    Gas/Electric use same set of t-stats and circuit board---common DC source
    Find out the model number and post.
    Then operation/wiring info can be posted in response
    And in addition to Model number...WHY do you need to replace????
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
