Winged_One
Sep 15, 2018Explorer
A bad converter?
2011 Coachmen Brookstone, 50 amp, with a Progressive EMS-HW50C inline that I installed 6 years ago.
This last camping trip of 4 days to Ludington Michigan State Park. 30 amp service. It seemed no issues from the park. No storms.
2nd day noticed the bathroom GFCI was tripped. Maybe first time since we have owned the trailer.
3rd day tried the living room stereo/dvd player. Acted very weird. Very slow running of the DVD. Would not seek out radio stations. No sound. Figured it had gone bad.
Everything else seemed ok. Fridge ran on AC without issue. TV's worked ok.
Arrive home. Plug into 20 amp service at home, just like we have when loading or unloading for the last 6 years.
Trips the GFCI outlet in the garage (where we plug in). The garage has its own circuit breaker (switchable) in the garage that then goes to a GFCI outlet. Same everything we have always used for 6 years. Checked breaker, GFCI, extension cord, all ok and normal.
Plug into the trailer, with the Progressive operating, shows no issues on the monitor panel (E0), 124 volts, normal. When Progressive lets the power through (like it normally does after several seconds), a "clunk" is heard in the area of the Progressive and an instant trip of the GFCI in the garage.
If I bypass the Progressive (with the switch on the Progressive monitor), instant trip.
There are 2 GFCI outlets in the trailer (stock). I have disconnected both. No change.
I turned off all the trailer breakers, applied power and no fault.
I then turned on the main breaker in the trailer, no fault.
I went through all individual breakers and no faults until I turned on the breaker labeled for the "converter". Instant trip.
I know I am asking a lot, but would you say the converter might have gone bad (or loosened connections)?
Might a bad converter explain the bathroom GFCI tripping and the stereo going bad?
Thank you again for any input you can provide.
