MrWizard
Jan 27, 2018Moderator
everything works on generator
some stuff does not work on shore power
you have either a bad shore cord
or a bad transfer switch
i know you say there is 110 at the TS, but there is a mistake in your diagnostics
you don't have a complete circuit supplying power thru the switch to the RV house breaker box, most likely one bad hot wire or contact
broken loose terminal in the transfer switch or shore cord
