jmf27614's avatar
jmf27614
A/C Freeze Sensor - How do I check a faulty sensor?
Our Dometic Penguin II low profile AC/Heat Pump has an intermittent problem. The AC compressor turns off after 2 minutes (almost to the second). The freeze sensor is plugged in and lodged into the c...
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
