jodeb720's avatar
jodeb720
A&E/Dometic Awning Question
I have an A&E Awning (16').
Product Number 958470040
Model Number is illegible but here's what I can see 916GU1 (either 8 or 0).xxxx (can't read the last four digits.
I ordered new awning, and when my son and I took the spring loaded end off the arm, he didn't listen well and let the tube spin, then pulled out the end.
I have no idea how many turns I need to make before attaching it back to the arm. I reassembled it with 10 tuns but it's not enough.
I can remove and increase it a couple of turns at a time but I'm sure there's a recommended number of turns, and it's going to be a slow process.
Does anybody know how many turns are the recommended number?
Thanks!
josh
  • Thanks Guys!!!
    This afternoon, when I was looking at my awning, I realized my able bodied assistant (son) wound it backwards!
    Good thing I know how to fix it!
    Again, thanks for the help!
    josh
  • Chris Bryant wrote:
    For the standard 16’ awning with the awning extended it takes 16 turns.
    x2
  • Mine was a little weak to start with so I used 17 and it worked better afterwards.
  • For the standard 16’ awning with the awning extended it takes 16 turns.
