ScottG
Aug 23, 2013Nomad
I have the problem almost every year in the spring. I just go up top and force the shaft to turn while using some oil to lube it. Been doing this for nearly ten years and it still works fine after freeing it up.
You may wan't to use something other than WD-40 - which is a lousy lubricant and wont last (it's not even a lube really).
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 05, 2025
