โMay-09-2015 11:10 AM
โMay-11-2015 05:05 AM
wa8yxm wrote:dougrainer wrote:
Your MAIN AC HAS a freeze sensor and will NEVER freeze up if it is installed and operating correctly. Your Bedroom AC does NOT have a freeze control. You need the unit checked out. It is under warranty. Doug
Mine does. (Have a sensor)
โMay-10-2015 03:45 PM
โMay-10-2015 03:17 PM
โMay-10-2015 01:24 PM
โMay-10-2015 09:16 AM
โMay-10-2015 08:23 AM
dsmith3 wrote:
Thanks to everyone for their contributions. In addition, here's an applicable blurb from owner's manual I found online...
OPERATION DURING COOLER NIGHTS
It is important, when the outdoor temperature drops in the evening or during the night to below 75ยฐF that the thermostat (temperature control) be set at a midpoint between โwarmerโ and โcoolerโ. If the setting is at โcoolerโ, the evaporator coil may become iced-up and stop cooling. During the day when the temperatures have risen above 75ยฐF, reset the thermostat switch to the desired setting.
NOTE: Should icing-up occur, it is necessary to let the cooling (evaporator) coil defrost before normal cooling operation is resumed. During this time, operate the unit in the โHIGH FANโ position with the system at maximum air flow. When increased or full air flow is observed, the cooling coil should be clear of ice.
โMay-09-2015 07:28 PM
โMay-09-2015 07:10 PM
โMay-09-2015 07:01 PM
โMay-09-2015 05:01 PM
โMay-09-2015 03:18 PM
โMay-09-2015 12:59 PM
โMay-09-2015 11:37 AM
RoyB wrote:
This always happened to my 13,5000BTU air conditioner when it was very humid at night...
Never did any damage but was a nuisance. Had to run fans only to melt the ice the next morning... It did help sometimes by running a couple of fans inside during those nights.
Roy Ken
โMay-09-2015 11:34 AM
