Lipets's avatar
Lipets
AC not starting correctly
If I turn on one at time no issue.
But if both are on and I plugin or start the generator, the transfer switch starts banging the jumpers like an over load.
if I shut one AC off temporally the other will run fine, then turn the second one on all is good.
It looks like the a/c start capacitor on one may be bad but can't tell which one
Suggestions?
the units are Dometic 630515.331
  • Turn off A/C before you unplug from shore power
    Start generator then turn A/C back on
    What you are doing swapping power with A/C running
    Is recipe for trouble
    A good way to fry the generator or burn out transfer switches
    Pull into camp turn off a/c turn off generator
    Plug in shore power, turn on a/c
    Never turn off or start generator with a/c on
    Big problems for generator
  • You should *never* plug in with high-draw appliances ON. This is how pedestal sockets get pitted and burned.
    Not too good for a cold generator either.
Having RV issues? Connect with others who have been in your shoes.24,213 PostsLatest Activity: Mar 13, 2025
