DiskDoctr's avatar
DiskDoctr
Add heatstrip n hardstart to Duotherm BriskAir conditioner?
Considering adding the SUPCO SPP6E and Dometic Brisk Air Conditioner Ducted Heat Strip to our new to us camper with a Dometic Duo-therm Brisk 13,500 BTU Air Conditioner, Model 57915
Questions I have.
1. Any problem with SPP6E version hard start vs SPP6? Benefits?
2. Is the 3105164.002 part the correct heat strip for my model?
3. Has anyone used an extra wall switch near the thermostat (I changed to digital non-programmable heat/cool thermostat) to switch between electric heat strip and propane furnace?
3a. If so, how do I get the Brisk Air system to fire up the heat strip and fan (currently wired for HIGH speed only)? I can work out a "special" DIY control if necessary, but I'd rather just duplicate someone else's simple solution- if there is one ;)
I'm not yet familiar with the internal wiring of the A/C and control unit. Because of the plug in and such that looks like it comes with the kit, I'm guessing there is some sort of designed control method?
Our hybrid is non-ducted and has a simple on/off rotary switch with a Heat setting (no thermostat).
I want to be sure this "new setup" works with the thermostat and retains the designed protections and such to not overheat and melt down the roof :E
Someone please tell me there is a good mod writeup for this!
Thanks! :)
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
