โApr-10-2015 08:46 AM
โApr-11-2015 04:30 PM
hammick wrote:
That's a great deal. I think I'll get this one.
โApr-11-2015 02:06 PM
โApr-11-2015 02:03 PM
Padlin wrote:
Back on the original posts question. Just went in with my brother and bought a 160w suitcase from Solarblvd. Planning to double up on the array inputs on the SC-2030, if there is room. Might use something like a power pole connectors and leave pigtails off the input. But then I can get to mine.
Manufacturer: Solar Cynergy
Model Name: 160W Foldable
Max Power: 160W
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 9.4A
Maximum Power Voltage (Vmp): 17.0V
Maximum Power Current (Imp): 10A
โApr-11-2015 01:28 PM
hammick wrote:
Almot tell us more about the Bogart CC without the Trimetric. I thought you had to have the Trimetric to do any adjustment.
โApr-11-2015 01:02 PM
hammick wrote:
Now you guys have me thinking about re-wiring the entire system with one of these:
http://www.amsolar.com/home/amr/page_34_16/refrigerator_vent_c-box.html
โApr-11-2015 12:49 PM
โApr-11-2015 12:35 PM
I could mount the Bogart CC behind the fridge and then run about 17' of 6ga wire to the batteries. Better yet I could steal the 6ga from my converter for the CC and then upgrade my converter with 4ga. It might actually go into bulk mode then.
โApr-11-2015 12:33 PM
grizzzman wrote:
So your controller has a shunt at the battery so it can tell exactly what is going into the battery compared to what is bei g used by the coach? If not then its a " best guess"
โApr-11-2015 11:43 AM
โApr-11-2015 11:38 AM
Almot wrote:
I know one, and own it. Infinitely adjustable - timer based Absorption, current based, you name it. Without assistance of Trimetric. The only feature that I could possibly use in Trimetric, would be its been-counting function ๐ - providing theoretical SOC based on AH in/out. Have figured out that, given the location, solar size and my energy use, I will have batteries full every evening anyway, so couldn't justify buying such a nice machine as Trimetric when there isn't much need.
So far so good. Not a solution for everybody, but then, solar isn't for everybody either. Wouldn't want bright Trimetric display in my room, they at Bogart should do something about it.
โApr-11-2015 06:45 AM
Almot wrote:grizzzman wrote:
How many solar charge controllers do you know that can run a bulk charge of 14.6 and when adsorb hits 3%of C20 it clamps the amps and goes into a finish absorb and allows volts rise to say 15.3 then holds it fom 0 to 4 hours? (User adjustable)
Or stop charging at a set amps? ...
Yes, I wouldn't put a 30A controller in a sealed box. Maybe doable with smaller controllers and/or in climates not awfully hot and sunny.
โApr-11-2015 12:00 AM
โApr-10-2015 09:41 PM
โApr-10-2015 07:23 PM
BFL13 wrote:
Yank your solar controller from where it is, and splice the array and battery wires together there. Now go to the battery bank and find the solar wires that go onto the battery bank.
Now insert your original controller by using the previous battery wires as the array side new wires to the controller and by adding new wires to be the controller -to- battery wires. Ta Da !
