Salvo
Dec 24, 2014Explorer
Yes it is an issue. Nobody likes listening to generators while dry camping. The longer the converter to battery cable, the longer it takes the charge the battery. This is not insignificant!
Treat the converter like the inverter. Install it as close as possible to the battery.
BTW, 12 feet of 6 awg cable is not good enough. Use 2 awg.
Ron3rd wrote:jcarlilesiu wrote:
I'm liking the idea of pulling the converter/charger and installing an inverter/charger.
What about my issue with the distance from the batteries to the converter being about 16 feet?
That's not an issue, but we sure to run the proper gauge of wire. The longer the run, the bigger the wire and the greater the $$! I've got about a 12ft run and if I recall I used 6ga.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
