time2roll
Jan 06, 2015Nomad
Shoe2728 wrote:Converter will have a timer to step down voltage.
I have an inverter in my fifthwheel and use it when Dry Camping. I have two batteries in parallel. My question is when plugged in to shore pwr the converter is charging both batteries, the converter is a three stage one and steps down as batteries are charged, now if one battery has a bad cell and cannot fully charge will the converter see this and continue to put out maximum charge and not step down, thus possibly boiling the good battery.
I was trying to find a battery isolater howerver the ones I find on the internet are for use with an alternator and not sure if you can hook the converter to that as a charging source
Still if you have a shorted battery the battery with a short will boil off the water, get hot and in some conditions explode. It is worth having them tested asap.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
