MikeInOregon
Aug 23, 2015Explorer
I attached a picture of what I have done. The range hood light switch is on the right in picture. The top connector is hot when the hood light switch is off. The top connector is not hot when the hood light switch is on.
I attached the red wire that leads to the new LED light to the top (hot) range hood light connection using the blue tap connector.
I attached the black wire that leads to the new LED light to the bottom (ground) range hood light connector using the blue tap connector.
It looks like I'm close to making this work, but apparently close is not good enough in horseshoes and electricity :) Please point me in the right direction.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
