Gdetrailer
Aug 11, 2019Explorer III
joebedford wrote:
Somebody suggested taking the tire off to give more room.
Take the DRUM off also, ESPECIALLY ON DROP AXLES.
That IS the ONLY way to get the brakes adjusted correctly.
YES, it does take additional time.
YES, it is messy.
YES, it works every single time with no special tools.
YES, this allows you to clean and inspect and regrease the bearings.
Besides, you SHOULD BE VISUALLY INSPECTING THE BRAKES YEARLY AT A MINIMUM.
Only adds 10-15 minutes per wheel to do it right every time.
In PA, we HAVE to have trailers over 3,001 lbs with brakes inspected yearly. Mechanic MUST pull one drum on each side as part of the inspection process.
One inspection station I went to only popped the plug and looked as best as they could through the plug opening at the brakes.. No way you can really get a good look at them so needless to say have never gone back to that place..
Why not do it yourself every year as part of your annual maintenance schedule?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
