EMD360's avatar
EMD360
Advice on new RV battery maintenance.
Here is the equipment in the stairs of our new RV.
The batteries are really corroded but they seem to be holding a charge. I’’d like some expert advice. Should I charge with the negative and positive on different batteries?
Besides wire brushing and checking the fluid what other maintenance would you recommend?
Should I check the solenoid and transfer switch or assume they are working correctly?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
