LittleBill's avatar
LittleBill
agm battery charge issue
what would cause a AGM battery to reduce its charging amperage, without the voltage reaching the set voltage cutoff in a CC mode stage of a charger
example, battery is at 13.6 yet a pd9245 in boost mode 14.4 confirmed, is tapering amperage
put a load on the battery down to 12.8 and its pulling the full 45 amps.
3 hours later its sitting at 14.4 doing 3 amps.
thoughts?
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
