hbarker
Dec 12, 2020Explorer
Air Conditioner does not act right "some times"
Dont know how to explain this but I will try.
Some times our main A/C when set to auto works perfectly.
Room gets cool , Compressor and fan shuts off till temp rises .
Then comes back on when needed to cool room when temp gets over setting. A sit should . AUTO
BUT ,. Some times when room reaches temp setting (say 75) Fan cuts off BUT only for a second. You can still hear the compressor running (humming-growl noise) then then Fan comes back on, Unit will not cycle as it should.
Unplugging the power to the rv and replugging it SOME TIMES corrects it . and Some times it does not .
Am I making any since >?? Something is causing the a/c unit to not work properly on the auto setting ,, But not all the time.
I can set it to Cool, blows constant as it should, and compressor cycles on and off with room temp setting. As it should.
Funny note I might add. This unit has been replaced 3 times under warranty. Yes thats correct THREE TIMES.
