โJun-14-2018 12:49 PM
โJun-15-2018 02:27 PM
dougrainer wrote:
ALL RV ROOF MOUNT AC UNITS RECIRC THE AIR. THERE HAS NEVER BEEN A RV AC UNIT THAT PULLS IN OUTSIDE AIR AND NEVER WAS AN OPTION TO DO THAT. Of course, I have only worked on RV AC's for 39 years. Doug
โJun-15-2018 01:55 PM
โJun-15-2018 01:53 PM
j-d wrote:
Doc, Your conclusions are correct. Some room A/C window units have a little passage that can be opened to bring in some outside air. We had an old Coleman Mach RV A/C that I thought had something like that, but it's been a long time so don't hold me to it. Our newer Mach does NOT.
BTW, that diagram is what you need to understand to periodically clean your Roof A/C. It's pictured without the plastic shroud. The angled shrouding over the Blue Part (evaporator) has to come off in order to clean the blue coil, and the drain pan and drain outlets directly under the blue coil. The red coil (condenser) may trap a few leaves but that's usually it. Notice, the air blows through from the front side of that coil.
โJun-15-2018 01:35 PM
drsteve wrote:Chum lee wrote:
If you still think an RV is air tight, drive one into a lake and see how long it floats!
โJun-15-2018 12:47 PM
โJun-15-2018 11:33 AM
โJun-15-2018 10:22 AM
Chris Bryant wrote:
There was a Coleman Delta T model that had an exhaust option, but I've only seen one, a long time ago.
Fwiw, I drew that diagram 17 years ago ๐
โJun-15-2018 09:28 AM
The Coleman Delta models were over 30 years ago and were quickly dropped from their line up. Doug
โJun-15-2018 09:22 AM
โJun-15-2018 08:29 AM
โJun-15-2018 07:54 AM
โJun-15-2018 04:55 AM
โJun-14-2018 03:34 PM
โJun-14-2018 02:53 PM
donn0128 wrote:
Actually RV air conditioners, at least all I have seen bring in air from outside suck it across the coils and dump cold air inside.
