Greetings!!
In the process of draining my rear air tank I noticed a leaking drain valve which is located in the engine compartment. It has an air line connected to it that leads to the air tank. This was confirmed by spraying a soapy solution on the valve.
Is this as simple as removing and replacing with a new one? I know that I will need to drain the tank first and will not need to crawl under the coach.
Is a replacement easily attainable?
Thanks for any feedback.
TZS and Wife :B
2007 Monaco Executive Sandia IV
Cummins ISX 525 Horsepower
Allison 4000 Six Speed Transmission
Roadmaster S-Series Chassis
2004 Ford F250
Blueox Aventa LX Tow Bar
SMI Air Force One
