mike-s
Aug 10, 2018Explorer
SidecarFlip wrote:Hardly environmentally friendly - see here. It has over 1000 times the "global warming potential" of CO2. Better than the old R-12, though.
Big thing for me is the quick cool down, much more consistent temperature control and no hazardous chemicals inside (compressor fridges use enviromentally safe R134.
Ammonia and hydrogen, on the other hand, have very little environmental impact. Concentrated ammonia can be corrosive and toxic, but that's about it unless you dump it on ground/water. A slow leak from an RV fridge isn't a threat. The vast majority of ammonia is made for use as fertilizer.
SidecarFlip wrote:Huh? My Dometic RM2652 draws about 0.7 A when running on propane, and I haven't bothered to disconnect the anti-condensation heater between the fridge and freezer. <1 A with the interior fans on. And that's when it's drawing power to keep the gas valve open.
A typical Secop/Danfoss compressor pulls less than 5 amps at 100% duty cycle and most time is pulling less than 2 amps. An ammonia fridge with auxillary cooling fans is approaching that and it's basically all the time.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
