Sarahps33's avatar
Sarahps33
Amp draw vs battery bank & solar array = totally confused!
Hey there, so I'm hoping some of yall have already dealt with this and could shed a little light.
Things aren't making since to me. I have checked each appliance's output power that I plan on bringing on the road.
For example my laptop says 20v/2.25a on the charger.
For each device like this I went to this website for a quick calculation: https://www.batterystuff.com/kb/tools/dc-to-ac-amperage-conversion-run-through-an-inverter.html
And I'd turn it into 12v DC - giving me the amp draw.
In the case of my laptop it was converted to 4.14a
I took those amps and multiplied it by how many hours a day I would use it.
The most I'd ever use it in one day would likely be 7hrs.
4.14a x 7hrs = 28.98a
So that tells me how many amps I'd use from that laptop a day, right? Am I doing it right so far? Lol.
I did this for my coffee maker, phone charger, flashlights, printer, and so on and came up with 348 amps that we could "potentially" use in a day if we used and charged everything we owned in a single day (I think that's overkill, but just in case right.)
And that's without a fridge. We want a fridge with a freezer so we can be off grid for longer periods of time. I have one now and if it ran 12hrs outta 24 it would be an additional 192 amps.
So the total with a fridge is 539
That seems like an awful lot to me. I dont understand how people have whole gaming systems, fridges, and microwaves and can run off a small batt bank.
Did I mess up somewhere?
I'm reading that AGM's have a depth of discharge rate of 80-50%. If we used 80% of each batt then we'd need seven 100ah batts just to run for one day! (539a/80a=6.7 batts at 100ah). If we wanted enough back up power for 2 days (say it was cloudy out) than we need 7x3 = twenty one 100ah batteries. That's what I dont understand....
But! I also understand that this is where solar charging rates come in. I've only seen 60a being one of the highest charge controllers. So does that mean I can charge with 60 amps an hour with my solar panels? (Assuming I have full sun light?) And say I have 4 hrs of full sunlight a day 4hrs x 60 amps = 240 amps charged per day.
With an amp draw of 539 it would take roughly 2 days and 1 hour to put that back into the battery bank. And that would still only be replenishing our daily draw but not as fast as we use it and wouldnt provide those 2 days of cloudy weather cushion.
I'm so in need of some help here, lol. I cant wrap my head around it.
Thank you so much in advance for any info you can give me.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
