tarnold's avatar
tarnold
Amps are amps...right?
Be nice ok? Size of wire determines current capacity (amps) as I believe. Recently had to replace a 30 amp fuse(U shaped). Had small size about same as a dime but needed next larger, about size of a nickel. Went to Autozone and got what I needed. They had same style that was about the size of a 50 cent piece, if you can remember what they look like. All 30 amp, so question, why the much different physical sizes, if all are still 30 amp rated?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
