Jetstreamer's avatar
Jetstreamer
Antenna reception diminishes after initial channel search
We’ll get somewhere,turn on the television and let the program conduct an automatic channel search. Usually finds a dozen or more over the air digital channels. When you search through the channel list most every one will come in pretty strong.
Ok - More often than not, by the following day, when I grab the remote and surf the previously found channels, most if not all will now come up with ‘no signal’.
I can’t understand why this happens. The antenna booster switch/system seems to be working as it should. I realize that signal strength may vary with time of day but it seems to be something other than that. Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
