BB_TX
Mar 02, 2020Nomad
Cummins12V98 wrote:dougrainer wrote:
They are installed to prevent holding tank ODOR from venting out the inlet fitting. Most BT flush inlets do NOT have a check valve like the City Water inlet because of the inside Check valve. If the OP's is NOT factory installed, then there is no upper Check Valve. The INLET and the inlet to the tank has a check valve, that comes with the aftermarket BT kit. Doug
They are check valves on the grey and black tank flush lines. They are there to keep contaminated water from siphoning into the public water supply.
Holding tanks vent thru the roof!
^^^^^^ This ^^^^^^
There are there for the same reason codes require anti siphon valves on outdoor water connections such as outdoor faucets and lawn sprinkler systems. There to prevent siphoning contaminated water back into the public water.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
