Anyone know what this is in the fridge? (Dometic)
timjcarter9
I noticed this hose like think sticking out from the back the other day:
Clicky
It appears to be a sensor but not positive. I pushed it back flush to the wall. Not sure if that was the correct thing to do. Anyone know for sure what this is?
2003 Avalanche - 4.10 gears
2010 Puma 18DB
Sold - 1973 FMC 2900R
6 REPLIES 6
timjcarter9
Thanks. Got it fixed now that I know where it was supposed to go.
2010 Puma 18DB
full-timer
That appears to be a Dometic frig. That is the Thermistor,it fits in a clip and clips on the cooling fin to adjust the temperature of the frig.
Joe
An Indian and a Gypsy
Joe and Nancy
2002 34 foot Georgetown double slide Ford V-10
towing 2004 Chevrolet Cavalier 4 Down
timjcarter9
neschultz wrote:
I think it is your thermostat sensor. My snaps into the white plastic bracket on the right side of the fins that slides up and down to regulate the temperature.
Thanks
That makes sense.
2010 Puma 18DB
neschultz
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
timjcarter9
Nope. Drain is on the left under the tray. Drains into a little built in funnel like outcropping then out the drain hose on the outside.
See here.
This thing has a solid end.
2010 Puma 18DB
Learjet
is that your drain line that should be connected to your drip tray?
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
