I have a 2018 Coachmen Freedom Express 292 BHDS Travel Trailer. The other day I noticed a bubble approximately 6 in. wide by 14 in. tall a few inches below the window on the back exterior wall. My assumption is that water is somehow getting in at the window and causing delamination. None of the windows have ProFlex caulking so I'm not sure what to do to stop the leaking. I have very little knowledge on this issue, what are my options? I hear it is expensive to fix. Unfortunately, my warranty has run out. What should I do?
This post is good but I have another issue which is related to my ac repair ***Link Removed***emergency ac repair when I started my ac it automatically off after few minutes also it leakage water, so o want a solution how to repair my ac.
