wa8yxm
Apr 08, 2016Explorer III
If you can park the trailer facing south, Mount the solar panels on the tong, (Not under the cover) NOTE: make sure the mount is secure so they do not grow legs.. Be sure to use a proper charge controller as well..
When you go on the road, you can use other options
Can't park facing south.. Well park the solar panels on the rear, again make sure they are very securly attached. Or you can pole mount 'em if the facility allows. If you have a long term slot, use a socketd pole (IE: Look at Sunsetter flagpoles for what I'm talking about) you can take the pole with you and fly the flag come July 4.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
