Phatty46290's avatar
Phatty46290
Atwood 85-11 rv furnace issue
Hello, new to the rv world and furnaces as well. I have a 1990-91 33ft silver eagle class a. Furnace has worked well overall until the last week. If I turn the unit on, it fires up and puts out good heat for maybe 20 to 30 minutes tops and then the heat just kind of bleeds away. When it's running and blowing cool air I'm pretty sure i can smell some gas coming from the furnace exhaust. I would like to clear the inlet air duct but how do I identify said vents and what's the best way to make sure they're clear?
1 Reply
  • Could be a number of things, but sounds like your inlet is clogged which tells the safety flame detector to turn off the flame.  The inlet has the air filter in it..  Can you trace the inlet from the furnace back into the camper to find the inlet?.  If cleaning the inlet doesn't work, clean the flame detector rod.  It keeps the furnace from overheating but if dirty it turns off the flame but some gas still goes up the exhaust.  Its easy to clean on most furnaces.  Turn off the power.  Look inside for a rod that is located in front of the burners.  There's usually one bolt that holds it on.  Take it out and clean it with emery cloth or brillo pad.  If that doesn't work, could be the control board, or at worst a cracked manifold.  Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
